engineering code
how can change engineering code for anther code
also anther equation if engineering code is disable this mean cannot access from any where by using IP static
change the engineer code from Security > Sign In codes
It is not necessary to set \"Require Engineer Code to write to Comfort\". This means you cannot use a user code to write to Comfort, but you must use Engineer code
It has nothing to do with Static IP address
4 Guest(s)
