control load by remote control
Hi,i wanted for every thing in side the room (( lighting , tv, socket power,window, air con,....))by remote controlby install IR receiver in rooms and this received code from remote control and sending to comfort  and in comfort controlling in load  for this room
this speak is correct or Not
RegardsHasan
That is basically correct
You need to use the RC01 remote control to send Comfort IR signals to IR receiver or IR dome
Download RC01 manual from https://www.cytech.biz/rc01_manual.html
Sir if have 5 rooms or more how can one remote to control all
please can be explain this point
In each room you can use the RC01 to send Comfort IR signals to the IR receiver
It does not matter how many rooms there are as long as there is IR receiver there
The IR receiver wll be connected to Comfort to activate Responses
Note that you need RIO01 to be connected to IR Receivers
thank you sir for support
sir but in comfort only one remote Rc01
for example programmed button 0 to work all light in room1
then if in room2 if press button 0 this causing run lighting in room1
i mean how divided code without any interface between rooms
also  remote Rc01  he consist 127 code Regards
There are 12 Room buttons in RC01
Each Room can be programmed to do different responses for each rooom
eg
Room 1 On  Off, off2,  On2
Room2 On, off, off2, On2
etc
This can be used to control things in different room
But all RC01 will have the same behaviour and control
thank you
you mean can be using same codes in all rooms by choice programmed rooms form 12 rooms in remote control
but problem all room have 4 function some time not have enough for programmed (( lighting(all on-all-off,some on , some-off), window (up-down), tv , air-cond, ...
also sir what mean in this picture
also this picture
I reading manual RC01 remote
in  manual  first row for 4 function for rooms  and  12 button for rooms  and 12 sence
now if go to programs Comfigurator  i see 128 code but how in maunal not speak about 128 code
I mean in IR Receive code from 0 to 95  and from 116 to 119
please how can using RC01 remote  to using this code
for more information i programmed no.100 to output1 on but any button in RC01 remote  must be press because i see all button in RC01 remote  is closed for some application
Please can explain how using RC01 remote  for IR receive code
Comfort can receive 128 IR codes via the IR receivers and any keypad with built in IR Receiver, but the RC01 does not send all 128. The other codes can be learned by a universal learning remote control. You can transmit the whole set of 128 IR codes from an IR transmitter connected to a Comfort Output to be learned by a learnin g remote control. In Configuration > IR Transmit codes, select Cytech, and you will see IR codes 0 to 127
In the IR Receive Screen that you showed, you can assign responses to the 16 scenes 0-9, A to E on the RC01 remote control. so pressing any of the scene buttons will trigger a Response in Comfort
For Rooms, go to Events > Room Responses
Each Room has 4 buttons 1,2,3,4 on the top names On, Off, Off, On
First press a Room button 1 to 12. Then press the function 1 to 4.
The functions for each room trigger a different response
Hence there are 12 x 4 = 48 functions by selecting a Room then the function button
The bottom section of the RC01 simulates the keypad keys so there is no programming needed.
You just point it at any keypad to make it work like the keypad keys on that keypad
