Known Bugs
- The reply to an SMS command to Control Key 5 gives the wrong text. It shows the text for control key 1 instead. However note that the sms operation works, only the reply is not correct
- Phone numbers with 7 digits will get the wrong reply when sending SMS to the UCM/GSM4. The UCM/GSM4 will always send the Help Text (1) and (4). This occurs if 7 digits appear in caller ID. Note that this may or may not include the country code, depending on the carrier. This problem has been reported in South Africa and Cyprus. Please upgrade to GSM4 v 7.048
