Need help on setting counter value
Hello expert,
I want to set KNX control in iphone Application (Switch On/Off light).Can you please give me some guide on this?
I have mapped 3 knx address (1-bit switching) to counter as below:
0/1/0 (Light 1) -> Counter000
0/1/1 (Light 2)  -> Counter001
0/1/2 (Light 3)  -> Counter002
Responses:
========SwitchOff: -----------
If  LastUcmCounter= 0
 Then  Set LastUcmCounter = 255
End If
SwitchOn: -----------
If  LastUcmCounter=255 Then  
  Set LastUcmCounter = 0
End If
Control Menu==========
Control Group 0- 
0- Room 1 (Feedback: Counter 000) 
   0- Off (Response: SwitchOff)  
   1- On (Response: SwitchOn) 
1- Room 2 (Feedback: Counter 001) 
2- Room 3 (Feedback: Counter 002)  
Counters=======
0 Counter000 NullResponse 
1 Counter001 NullResponse 
2 Counter001 NullResponse 
When I try to execute response, I did not get the expected result.
The way you have programmed it, you will not be able to control the KNX lights from your control menu.
\"If Last UCM Counter \" should be used only in a Counter Response, NOT in a response sending commands to KNX. \"If Last UCM Counter\" is used for KNX to control Comfort not for Comfort controling KNX
The On Response should be eg
 KNX 0/1/0 On
Off Response should be eg
KNX 0/1/1 Off
Use the Response Wizard to program the KNX Commands
This is explained in detail in the UCM/KNX Manual which canbe downloaded from https://www.cytech.biz/ucmknx_manual.htm...ory_id=107
Hi ident,
Thanks for the help and I got it working now.
