01-09-2014, 12:08 PM
Does the Universal UCM support the RFXLAN Transceiver please?
http://www.rfxcom.com/store/Transceivers/11201
RFXLAN Transceiver support
01-10-2014, 01:51 AM
Yes the Universal UCM with ethernet supports the RFXLan , one way, ie Comfort can send commands to it. I will look for an application nore
01-10-2014, 09:20 AM
Thanks.
Just to clarify, as I was under the impression that the Universal UCM was capable of two-way communication, are you saying that Comfort will not see any data received by the RFXLAN? If I have understood this correctly, is there likely to be any two-way support for the RFXLAN in future?
01-10-2014, 01:17 PM
The universal UCM is capable of 2 way communications through 1 TCP port, but the RFXLan device requires 2 TCP Ports, 1 in each direction
Hence the UCM is able to talk to this device in 1 direction only I cannot say if we would go on to develop a 2 way interface, it demands on the demand
01-10-2014, 01:27 PM
Thanks for explaining.
One final question on this subject. Is the Universal UCM able to communicate with the xPL version of the RFXLAN? http://www.rfxcom.com/store/Transceivers/11202
01-10-2014, 01:39 PM
No we have not tried the xPL version yet
| 3 Guest(s) |
