The following Relay Modules are available for various control purposes
RLY01H
4 Changeover Relays (1 Form C) rated at 230VAC or 30VDC, 4 Amps for switching or dry contact.
12V Coil can be connected to Comfort 12V outputs
RLY01H is a replacement for RLY01 which was only for low voltage switching < 30V
Download the manual from https://www.cytech.biz/rly02_relay_manual.html
TWS02
2 Relays and Current Sensors for On/Off switching of lights. Download the manual from https://www.cytech.biz/tws_manual.html?category_id=118
The LRM02 shown below is a better solution to switching of lights
RLY02
8 Reed Relays for low voltage switching rated 30V 500 ma. Download manual from https://www.cytech.biz/rly02_relay_manual.html NOT for High Voltage switching
LRM02
2 latched Relay Modules rated at 230V 16 Amps (resistive)
Used for switching lights. Current sensor CSM03-CT and CSM03-PCB can be used for sensing current
Download the manual from https://www.cytech.biz/latched_relay_module_manual.html
OP04
Output Submodule with 4 Relays, plug-in to CM9001 in place of OP01This connects 4 relays to Outputs 1 to 4 of CM9001. Outputs 5 to 8 are not available when OP04 is plugged in
RLY01H
TWS02
RLY02
LRM02
OP04
