UCM/GSM4
The Comfort UCM/GSM module has the following functions;
  • Acts as a backup for dial-out on alarm activation when the land line is faulty or cut. Alternately, it can be used without a fixed telephone line, for installations where a telephone line is not available or not desired. Comfort\'s dialer can dial to 8 telephones which can include mobile or landline phones or Central Monitoring Stations.
  • Allows the user to dial to the GSM number instead of the fixed telephone line to access Comfort Voice menus.
  • Comfort  reports alarms to the users cellular phones via SMS. The SMS message will show the alarm type and Zone description as text.eg \"101 Back Lane Road - 01 Intruder Alarm - 03 Back Window\"
  • Allows users to send commands to control home appliances and the security system via SMS, and receive status of the command by return SMS.
  • Only authorised Mobile phones can send commands and receive messages from UCM/GSM. Each phone is individually authorised to arm, disarm or control  automation
About SIM cards
[color=\"#ff0000\"]Note that a standard size SIM card is required for UCM/GSM4. This should not be password protected. It should not be a 3G or 4G only SIM card, and should be able to send SMS messages on a mobile phone. UCM/GSM4 uses 2G technology and mobile networks which do not support 2G cannot be used
The new UCM/GSM4(3G) model works on 3G only networks like 3. See http://www.comfortforums.com/forum48/4593.html
[/color]
SMS messages can include, Alarms, Arm, Disarm, Bypass with Zone names and User names, as shown below
The  new UCM/GSM4 Module  has the following features and improvements to the SMS functions;
  1. Send \"?\" or any invalid text to UCM/GSM will cause a Help message to be returned by SMS. The Help messages will include commands to query, arm and disarm the security system, as well as commands for the Control Menu to query and control devices
  2. When UCM/GSM sends SMS messages to programmed phones, the alarm names, Zone Names, and User names can have up to 32 characters. The SMS alarm messages will be preceded with a Time Stamp so it can be seen when the SMS is sent - this is useful because of possible delays to SMS caused by the GSM network.
  3. User Names can be sent in SMS messages eg when the system is armed and disarmed instead of User Numbers
  4. Each of the max 8 programmed phones can be individually authorised to Arm, Disarm, and Control Comfort.
  5. 2 Phone numbers can be programmed to send SMS in case te UCM/GSM loses communications with Comfort (in addition to the 8 numbers)
  6. Non-english alphabets are supported
  7. Long text messages more than 160 characters Concatenated into a single message.
Minimum Requirements
  • Comfort firmware 7.046
  • Comfigurator 3.7.8 and above
  • UCM Firmware 7.04x
  • UCM/GSM4 canot be used with LGX01, UCM/Logic, KNX/Loigc
The UCM/GSM4 manual can be downloaded from https://www.cytech.biz/product_details.php?item_id=205
These are examples of the new SMS features of UCM/GSM4
sending ? or any invalid SMS to UCM/GSM4 returns the Help info
sending SMS (1) replies
Note that it gives the Comfort security mode, AWAY Mode in this example, followed by the valid commands to arm and disarm the security system
Send (10) to disarm the system. This is only allowed if the Phone Permissions for the mobile phone allows Disarm by SMS.
The SMS reply shows Away Mode and the help menu
If the Disarmed Alarm Type is enabled for SMS to this phone, an additional SMS for Disarmed is sent to the phone with Time Stamp and showing that the system is disarmed by SMS.
Arm to away by sending (11). This is permitted only if the Phone Permissio.ns for this phone allows Arm by SMS
When Comfort sends SMS due to an alarm it will include zone or user names eg
 eg the above SMS show the system in Cytech Technology armed and disarmed by user \"Mr Big\" with the time stamp of each event
sending SMS (4) will give a reply by SMS;
This is an example of a Home Control Menu which is programmed in Comfigurator
Sending (41) will give a reply for the items in the Lights Menu
Sending (411);
This tells you the Side Lights are OFF and the commands for controlling Side Lights
Send (4111) to turn on the side lights
The help system gives the valid commands at each step
In Comfigurator 3.7.5, Phone Permissions are available for the current UCM/GSM and UCM/GSM4
Each of the 8 mobile phones has individual permissions for
  1. Allow SMS Control ie the \'(4)\' menu
  2. Allow SMS Arm ie the \'(1x)\' menu
  3. Allow SMS Dissrm ie the \'(10)\' menu
Another feature of Comfort 7.037 is that SMS are sent with a Time Stamp
If the command is not allowed because of the Phone permissions, eg if a command to disarm the system (10) is sent, and \"Allow SMS Disarm\" for that phone is not permitted,  the reply will be
The multi-Language capability of the new GSM fiirmware 7.034 is shown in the example below
40 is English.
41 is Traditional Chinese.
42 is Thai.
43 is Arabic.
44 is Greek.
45 is Vietnamese.
46 is Tamil.
47 is Esperanto.
The possible languages are not limited to the examples shown!
in GSM4 Properties, set the \"English\" field to NO.This will reduce the numbetr of characters by 1/2
The GSM status bar shows the current status of the UCM/GSM. The status bar can be seen on the bottom left of the GSM configurator screen
It is useful in case there are any problems getting the GSM module to work
Possible status values are
\"Normal/No error\"
\"EEPROM missing/faulty\"
\"EEPROM insufficent capacity\"
\"EEPROM data invalid\"
\"Communication error between UCM baseboard and sub-module\"
\"Unknown error\"
\"GSM Network Strength 0 - No Network\"
\"GSM Network Strength 1 - Weak\"
\"GSM Network Strength 2- Fair\"
\"GSM Network Strength 3 - Good\"
\"GSM Network Strength 4 - Excellent\"
\"Initialising UCM/GSM\"
\"Call in progress.\"
\"No SIM card or SIM error.\"
\"SIM card requires PIN code.\"
\"Not Sim900 GSM module.\"
\"Send SMS queue full.\"
GSM Network Strength should be at least 1 to be able to work well. If it is 1, try to use a higher gain antenna or find another locatio for the UCM/GSM
Note the UCM/GSM has vbeen replaced by UCM/4G for 4G/LTE networks, se http://www.comfortforums.com/forum48/5420.html
4 Guest(s)
