12-11-2013, 09:30 AM
Currently I\'m using C-Bus DLT switch with KNX actuator using CBus KNX Translator. But we are facing DLT switch screen on & off even with CBus power supply. Any solution to this. Pls advice. Thank you very much
C-bus DLT switch to KNX Translator
12-16-2013, 02:09 AM
Sorry for the delay in responding
Are you sure that the DLT problem is due to the Cbus to KNX translator? How exactly does the screen switch off and on? You mean that it switches off after a whille? Is this not the normal behaviour? Please describe in detail exactly what is not correct, and we need to have the programming file for your configuration. Please send to support@cytech.biz or attach in your reply |
« Next Oldest | Next Newest »
