Hi Chiu:
Thanks for your response and apologies for leaving out the word \"sometimes\" in my original post!
I\'ve spent hours trying to repeat the problem, but have not been able to do so. Was starting to think that I\'d lost my head
hock:
, when I found another strange problem, this time with the \"If Flag\" statement - see \"problem 2\" below. Am trying to tackle this one in a step-by-step and more scientific way!
But first, some more about the \"Counter\" problem. When I leave the \"Counter\" word out, it DOES complain about the syntax and I\'ve been unable to repeat the problem. But I found four or five instances in my code where the word had been left out. These instances were found during different editing sessions, meaning that the ccl was loading \"successfully\" into Comfigurator. Also, the only way it could have been originally coded without the \"Counter\" is in Comfigurator as I\'ve not edited the ccl outside of Comfigurator. (I\'ve also just done a test using a text editor - Comfigurator DOES complain about the syntax on loading the file!)
When this first occurred, I had spent hours looking for a problem in my code when a response wasn\'t behaving as expected. I had opened and closed this particular response numerous times while making small unrelated changes in trying to debug the problem, and then, on one occasion, on clicking OK, Comfigurator suddenly complained about the syntax! I assumed that I had made the error previously. But I was more concerned about how this could have happened in the first place and why Comfigurator hadn\'t complained when loading the file! I have had a few instances where Comfigurator (or maybe some external influence?) has completely corrupted a ccl from a certain point onwards on saving the file so I do feel that there may be some obscure bugs somewhere (as they say, there\'s always one more bug!
). But this wasn\'t a complete or random corruption - it\'s a very subtle, specific occurrence. If it happens again, I\'ll try to be more exact with my observations.
Problem 2:
Didn\'t save a copy of the ccl with the \"Counter\" problem, so, hoping I had some more instances of this which I could investigate in more detail, I\'ve just searched through the ccl with a text editor to check all the \"If ...\" statements and found the following:
\"If Flah flagname Then\"
Yes, that\'s an \"h\" instead of a \"g\" in \"Flag\". Comfigurator loads the ccl without complaints. If I make an unrelated change to the response containing the \"Flah\", thereby forcing a syntax check(?), the response is saved silently. Guessing that the syntax checker may only be checking the first 3 characters or something like that, I then changed a later Flag statement in the same response to Flah - the syntax checker complained. I also changed \"Flag\" to \"Flah\" in another response - the syntax checker also complained!! I then created a new response and cut & pasted from the \"Flah\" response into the new one - NO complaints from the syntax checker! Have also edited the Flah to Flag, saved the response, opened it again, changed Flag back to Flah - NO complaints!:?
Right now I don\'t have the time to do further checks nor test whether the statement works as expected or not - will do this when I can and report back - unless you beat me to it and find the problem!
Comfigurator 2.1.1 beta?!?! When can I have it?
Regards,
Leon
