When the system is armed to Night mode, motion detectors may be active.
This may cause false alarms when people forget to disarm the system when moving around the house
It is possible to start an entry delay in Night mode when the detector is triggered so giving users a chance to disarm the system
In the Zone Response of the detector assign a Response as follows;
If Security Mode = Night Mode
Start Entry Delay
Endif
Another application is in Night Mode, opening a window will cause an alarm
People often forget that the system is armed, and open the window causing an alarm
It is possible to start an entry delay when an internal motion detector has been triggered first
The Motion Detector Response is programmed as follows
If SecurityMode = NightMode Then
Do NullResponse After 30 Seconds Using nightWindowTimer
End If
This starts a timer for 30 seconds. During the 30 seconds opening the window is programmed to start entry delay
The window Zone Response is programmed as folows;
If Timer nightWindowTimer <> 0 Then
Start EntryDelay
End If
This starts an entry delay only if the nightWindowTimer is running
Change Entry Delay can be placed before Start entry delay to use a different entry delay than the normal entry delay
Start Entry Delay
Endif
End If
Start EntryDelay
End If
