07-23-2013, 11:51 AM
HI All,
I have been getting some help from admin but they cannot replicate this issue- I think it is an issue with the UCM CBUS as my CBUS network appears fine (all buttons work & status is updated in the toolkit). Within Comfort the status of each CBUS takes a minute or so to update, I am also unable to issue any commands for example turn lights off or on. It looks like Comfort issues the command but it receives the same response everytime.
Admin have suggested I return the module but I would prefer to try and identify the issue before I send it off for repair / replacement.
When I issue a command I always get the same response back
< RA0000 for example selecting a response: Cbus On UCM02 3 I get the following:
> DAC5120379FF
< RA0000
The strange thing is that if I remove the wiring from the CBUS Sim and then put the wires back in it appears to work fine for 10 minutes and then stops again.
I have checked all wiring and replaced the wiring between the UCM Cbus & Cbus. can anyone give any suggestions as to what may be happening.
Hopefully I can resolve before having to return the module.
> DAC5120379FF
< RA0000
