KP06 and SCS
Hi all,
I am looking to mount a kp06 and an SCS in the same frame - is this possible? I seem to remember seeing a picture of such a configuration not sure if this was done by using custom frames etc.
Can someone also tell me where I can buy the 3 gang back boxes in the uk?
Would I need to run two cat5 cables to this combination or are they daisy chained?
Any info people can share on how to install system 55 would be really appreciated.
Paul
I have seen 1 gang stackable backboxes that can be clipped together to form multigang
The round backboxes are not suitable as the PCBs require more room that allowed by these
You need a GIRA backbox and frame
part no 2883 20X
X IS THE MATERIAL OF THE FRAME
1= WHITE
2= S/S
3= ALUMINIUM
Contact www.knxshop.co.uk
regards
Niall
Hi Niall,
Thanks for the reply, I had been looking at that part but was put off when it said E22 on the website - are System 55 and E22 the same thing just by a different manufacturer?
Also this is going in a solid wall, are there any versions for solid walls? If not can it be used like a standard UK dry linning box?
Many Thanks
Paul
Hi Paul
System 55 is a range of devices made by Gira
they then have a range of frames for them
ie: event,esprit,e2 e22 etc
System 55 is taken from the dimensions of the devices 55 x 55 mm
a standard uk back box won\'t work for you on this
If your fitting the 2883 20x box in a solid wall you will also need part no. 289300 I think there about 8 euro
let me know if you want them
regards
Niall
