Comfigurator Licence
Hello,
I purchased a Comfort (1) Pro system some late 2005. In the last few weeks I connected a serial UCM and downloaded the latest version of Comfgurator 2.10. to connect to Comfort. However, it tells me that I will be only able to run this for 30 days before purchasing a licence.
I thought the cost of this licence is included in the cost of the comfort system???
LiamK
There are 2 types of UCMs;
UCX01 without Comfigurator licence, used for interfacing to external devices like Lutron etc
UCM01 or UCM/IR used for upload/download which comes with the Comfigurator licence
There is a cost difference between the 2
If you are getting the message then you must be using the UCX01
Were you informed of the difference when you purchased it?
No, it\'s a serial UCM01 with the Audio, got it from Letsautomate. They did not mention any software licence cost.
Regs
LiamK
Letsautomate purchased a batch of Comfigurator licenses for resale, and so I believe they should have supplied you with one.
Malcolm Green
Hi Chiu
Same hapened with me. UCM01 got some high power via 485 bus and as long as fortunatelly it was only single board damaged I purchased second hand UCM01 Audio from another user who purchased GSM module instead. UCM Audio was originally purchased around 2005.
When I tried to upload previous ccl file I got message that licence will expire in 30 days
How is possible to get licence key to activate Comfigurator?
Mindaugas
