SEM 6.068
The changes in SEM 6.068 are
  1. Removed potential problem with firmware upgrade by Bus
  2. Improved watchdog operation so firmware does not hang due to surge
  3. Watchdog timer increased to 18 secs
  4. RS485 Receive buffer size from  127 to 240 bytes
  5. Fixed Bug Scan for Slaves 4,5 did not work
  6. Firmware Upgrade erase Flash reduced time to less than 2 seconds
The SEM firmware can be upgraded in Comfigurator 3.6.5 by right clicking on the SEM and select \"Check for Updates\"
As I was upgrading my SEMs last night and comparing the two methods (Using Local file or Check for Updates), I realised that with local file I would download the file once and use it multiple times to upgrade multiple SEMs, while with the second option, I guess the upgrade file is downloaded multiple times.
How about an option to upgrade ALL same generation SEMs in one go?
It is not possible to upgrade every one at the same time
Each upgrade needs many commands and data to be sent to the module, and the software must monitor that the commands are successful and there are no errors, and if there is an error, the software needs to handle.
hence only one can be upgraded at a time
The new upgrade method makes is very easy to upgrade firmware compared to before
I was thinking more of a single click and having the process update one SEM after the other (if there are no errors of course).
In the future we may consider a possibility of upgrading all firmware one ofter the other
5 Guest(s)
