KT03 7.012 (Beta) firmware can be downloaded from https://www.cytech.biz/product_details.php?item_id=266
Changes in this version include
- KT03 will detect if it is not polled or if there is a clash in IDs (Duplicate IDs) and display a message, and also allow the ID to be changed in Settings without needing to enter the user code
- Calibration accuracy has been improved
- Implement new ID setting method by Comfigurator
- ID of FF means ID is unassigned.
- Fixed Rectangular Border Misalignment near the right edge of the screen
- Settings page Keypad size of buttons has been enlarged to match the default keypad page buttons
- Improved Firmware upgrade reliability and faster time to erase Flash.
- Firmware Upgrade by UCM through Comfort Bus has been implemented (as well as through KT03 USB Port)
- Write to Comfort by Bus has been implemented (as well as through KT03 USB Port)
- ID of 8 is invalid. When reset the ID will revert to FF (Unassigned)
- When Trouble alarm is restored, the OFF LED will turn off instead of steady ON
- When Alert or Alarm state occurs, the AC LED flashes instead of the ARM LED
