Comfort Firmware 7.013 to 7.024
Comfort Firmware 7.013 Beta has the following changes;
  1. Scan for modules will report modules that are not currently polled by Comfort. The u? Reply has been extended to u?nnTTVVRRFF where nn = id of module, TT = Product Type, VV = Firmware Version, RR = firmware revision, FF = 00 for ID good and FF for ID bad or not polled. Module that does not reply will have a report u?nnFFFFFFFF.
  2. Added action code  Get Parameter 73,30 = Get Last Security Mode. Can be used to check what was the last security mode which the system was armed to.
  3. Added Action 120 Compare sensor compare inputvalue against sensor.
  4. Added  action 153  load user value 2 bytes
  5. Added 2 byte Conditional branch actions Action 184 = Branch if equal, 185 =  Branch if <>, 186 = Branch if >=, 187 = Branch if <, 188 = Exit if equal. The 2 byte values are signed ie can be positive or negative using two complement notation.
  6. Report counter broadcast 2 bytes when any counter changes
  7. Fixed BUG reset action 118  reset ID may not have worked
  8. Fixed BUG from ULT 7.009 - false Communications Failures may be sometimes reported
  9. Fixed BUG when trouble happens while in keypad menu and is restored before exit, KP06 and KT03 trouble remains and cannot clear. Bug Did not affect KP04 and KP03
  10. Logic Engine does  not require Engineer sign in to upgrade firmware Does not affect other  Comfort models
Known Bugs
  1. Related to UCM/GSM. SMS messages do not show Zone Names correctly
  2. Scan for Modules where the module firmware does not support the scan command will report wrongly as module not found
  3. Copy Counters action does not work
  4. Say Words action does not work using a UCM Do action command
  5. if actions Bypass, Unbypass Key arm, Auto arm or Activate Door stations are followed by other actions in a Response, then the other actions are not done. Workaround is to place the above actions as the last action in a Response
  6. Actions  35 (Save Last Counter( 37 (Save Last Sensor), 121 (save Input value to sensor), 151 (Initialise Sensor) do not save the correct value
  7. Action 148 Multiply by Constant gives wrong result. But multiply by counter and Multiply by sensor do work
  8. Reminder Enable function does not work for Reminder Numbers 9 to 16. Reminder Enables for 9 to 16 are the same as Reminder 1 to 8. This affects Scheduled Reminders only.
  9. Vocab Upgrade fails during the sentence upgrade process with Error Code 29. If this happens, repeat Sentence Upgrade only, not the full Vocab Upgrade
Note New Action codes  are not yet supported in Comfigurator 3.6.4
The firmware can be downloaded from https://www.cytech.biz/comfort_ultra_fir...ory_id=101
ULT 7.014 fixes the bug for sending SMS without zone names (from ULT7.009)
Known Bugs
  1. Scan for Modules where the module firmware does not support the scan command will report wrongly as module not found
  2. if actions Bypass, Unbypass, Key arm, Auto arm or Activate Door stations are followed by other actions in a Response, then the other actions are not done. Workaround is to place the above actions as the last action in a Response
  3. Actions  35 (Save Last Counter( 37 (Save Last Sensor), 121 (save Input value to sensor), 151 (Initialise Sensor) do not save the correct value
  4. Action 148 Multiply by Constant gives wrong result. But multiply by counter and Multiply by sensor do work
  5. Reminder Enable function does not work for Reminder Numbers 9 to 16. Reminder Enables for 9 to 16 are the same as Reminder 1 to 8. This affects Scheduled Reminders only.
Comfort Firmware ULT 7.015
Fixes bug where Scan for Modules where the module firmware does not support the scan command will report wrongly as module not found
Bugs in 7.013 to 7.015
  1. Copy Counters action does not work
  2. Say Words action does not work using a UCM Do action command
  3. if actions Key arm, Auto arm or Activate Door stations are followed by other actions in a Response, then the other actions are not done. Workaround is to place the above actions as the last action in a Response
  4. Actions  35 (Save Last Counter( 37 (Save Last Sensor), 121 (save Input value to sensor), 151 (Initialise Sensor) do not save the correct value
  5. Action 148 Multiply by Constant gives wrong result. But multiply by counter and Multiply by sensor do work
  6. Reminder Enable function does not work for Reminder Numbers 9 to 16. Reminder Enables for 9 to 16 are the same as Reminder 1 to 8. This affects Scheduled Reminders only.
  7. Vocab Upgrade fails during the sentence upgrade process with Error Code 29. If this happens, repeat Sentence Upgrade only, not the full Vocab Upgrade
A bug has been confirmed in Firmware 7.013 to 7.015 -  if actions Key arm, Auto arm or Activate Door stations are followed by other actions in a Response, then the other actions are not done. Workaround is to place the above actions as the last action in a Response
ULT 7.017 has been released
This fixes the bugs in 7.013 to 7.015
  1. Copy Counters action didnot work
  2. Say Words action did not work using a UCM Do action command
  3. if actions Key arm, Auto arm or Activate Door stations are followed by other actions in a Response, then the other actions were not done.
Known Bugs
  1. Actions 35 (Save Last Counter), 37 (Save Last Sensor), 121 (save Input value to sensor), 151 (Initialise Sensor) do not save the correct value
  2. Action 148 Multiply by Constant gives wrong result. But multiply by counter and Multiply by sensor do work
  3. Action Bypass and Unbypass cause following actions to be corrupted
  4. Reminder Enable function does not work for Reminder Numbers 9 to 16. Reminder Enables for 9 to 16 are the same as Reminder 1 to 8. This affects Scheduled Reminders only.
  5. Vocab Upgrade fails during the sentence upgrade process with Error Code 29. If this happens, repeat Sentence Upgrade only, not the full Vocab Upgrade
ULT 7.021
  1. Action 117 Change Entry Time action will apply only when  the security if armed, so  a zone open when security if  off does not affect other zone entry times later.
  2. Fixed BUG from 7.013 actions 35, 37, 121, 151 did not work
  3. \"Multiply by Constant\" Action fixed Bug did  not work from 7.006
  4. Multiply actions handle negative values for 2 byte values for Counter, Sensor and Constant.
  5. Convert F to C and Convert C to F actions handle negative temperature values in 2 bytes format
  6. During Entry Alert, a non-entry path zone activation causing a warning alarm will be recorded in the Event Log. Before the non-entry zone was not in  the event log.
  7. Logic Engine can respond to a? , K? And Z? So it work with android and iphone app
Bugs
  1. Action Bypass and Unbypass cause following actions to be corrupted
  2. The local phone is interrupted by the phone relay clicking
Bug found in 7.013 to 7.021
  1. Actions 75 Bypass and 76, Unbypass causes following actions  in the Response to be corrupted
  2. Reminder Enable function does not work for Reminder Numbers 9 to 16. Reminder Enables for 9 to 16 are the same as Reminder 1 to 8. This affects Scheduled Reminders only.
[user=86]ident[/user] wrote:
So, the work-around would be to downgrade to 6.028?
We have found and fixed the problem, ULT 7.022 will be available soon
