01-15-2013, 11:30 PM
when configuring comfort to send IR codes learned from my remotes i found that that all my appliances only work when i extend the IR cable and point direcly to the receiver, about 1 meter distance. Even for one of the A/C (Fujitsu) i installed the receiver about 1 meter LOS and it does not always work.
My tested appliances are:
2 different Fujitsu A/Cs
LG TV
Panasonic TV
I troubleshooted with a IR receiver that turns on a led each time i detects signals and i have verified that it is possible to even receive wall reflected signals, my guess is that the original appliances find the signal too low and discard it.
I\'m kind of confused, is this the expected behavior? do i have to install a IR transmitter right in front of each of my appliances? Am i missing something?
I can try the outputs on the main comfort to see if there is any difference. I\'d be grateful if someone could share with me some tips on this, since i was expecting a performance similar to the original remotes that work almost in ever angle/position.
My set up:
- comfort Ultra II 7.005
- UCM USB 7.002
- UCM KNX 6.024
- RIO 2.007
- 13 16A relays - finder 40.61
all in the same enclosure powered with the original 12Vac transformer that came with the bundle.
- SCS 6button about 5 meters away
Best regards,
Cab123
LG TV
Panasonic TV
My set up:
- UCM USB 7.002
- UCM KNX 6.024
- RIO 2.007
Best regards,
Cab123
