Threads: 19
Hi I have tried to activate the doorbell response but cannot get it to function, I have a fermax citymax connected to DM02. I have tested activating a response by adding it to Events, Misc Events, Doorbell response.
I tried with my own response and then changed it for the one on your tutorial with play reminder message. None of them worked- the doorbell stays the same as it always have.
Do you know why the responses might not be activating?
Threads: 476
The Doorbell Response should definately work when the doorbell button is pressed and is detected by Comfort, ie the keypads chime
Try assigning a Response that you know definately works, like turn on a light that you can see
If you have problems send the cclx file to support@cytech.biz
Threads: 19
Thanks for the quick response as always, I added in \"do a response I know works\" and strangely it then did that response and played the reminder message that wasn\'t working. I will try and do some more programming and see how I go.
Threads: 19
Hi Quick question, I want to be able to select which phone number the doorbell rings when pressed based upon a flag. I.E if flag user 1 <>0 then dial user 1, if flag <>0n then dial user 2. if no flag is checked then do not dial out but divert to answerphone.
Is it possible to do this? I only want the phone to dial out when I tell it to.
Threads: 19
Another request to add to this is, is it able to set the fire alarm to only dial out in away mode or day mode? I don\'t want it ringing my mobile when I\'m home
Threads: 476
There is an Action \"Limit Dialout\" where you can select the Phones 1 to 8 for dial out when an alarm is activated
The Doorbell Alarm Type should have dial out checked for all the phones that you want to dial to
The Limit Dial out action can be used to limit the dialout to those selected by the checkboxes. You can use logic with the Limit Dial out flag
This action must be in the Doorbell alarm Responses
Threads: 19
Thanks I did try the limit out and limited to none but it still dialled my mobile. I will try again in case did something wrong
Threads: 476
check your firmware as some of the features are not implemented in old firmware
Upgrade to the latest
Threads: 19
Thanks firmer is the latest
