RC01 Remote Control
[font=\"Verdana, sans-serif\"][size=\"1\"]The low cost Comfort Remote Control RC01 sends infrared signals to an infrared receiver; either a KP03/KP04/KT01 keypad or infrared receiver IRR01 connected to a Remote Input/Output (RIO) module to control any programmed operation via Received Infrared Responses. There are 128 infrared (IR) Comfort codes, each of which can activate a programmed Response. Comfort IR codes can also be sent from universal learning remote controls like the Philips Pronto and Logitech Harmony. The RC01 is a lower cost alternative to the Pronto which sends fixed IR codes to Comfort.[/size][/font]
[font=\"Verdana, sans-serif\"][size=\"1\"]The RC01 buttons are divided into several sections;[/size][/font]
[font=\"Verdana, sans-serif\"][size=\"1\"]The top section consists of 4 function buttons in the first row and 12 “Room” keys. Pressing a Room key 1 to 12 selects a room or area or device to be controlled. Pressing one of the 4 function keys in the first row activates a Response to perform the required task depending on the last Room Key pressed, for example, controlling a light, or TV or appliance. Room keys themselves do not activate Responses, they just select the active \"Room\". The Function keys will activate Responses based on what Room is active.[/size][/font]
The “Scenes” section contains 12 buttons, each of which triggers a scene (activates a Response directly).
[/size][/font][font=\"Verdana, sans-serif\"][size=\"1\"]Buttons A, B C, D around the central oval area are for 4 additional scenes.[/size][/font]
[font=\"Verdana, sans-serif\"][size=\"1\"]The 2 Panic keys in the middle of the remote control when pressed together cause an immediate Panic alarm in Comfort.[/size][/font]
[font=\"Verdana, sans-serif\"][size=\"1\"]The keys in the bottom section are keypad keys. When pointed at a Keypad, these keys function just like a keypad, i.e. the remote control becomes a remote keypad, with the voice coming from the Keypad at which it is pointed. The keypad buttons will not work with an IR receiver connected to the RIO (remote Input/output). RC01is availoable in yellow or purple.
The RC01 manual can be downloaded from [/size][/font][font=\"Verdana, sans-serif\"][size=\"1\"]https://www.cytech.biz/manuals.html
[/size][/font] [font=\"Verdana, sans-serif\"][size=\"1\"]Note: The RC01 is not a learning remote control[/size][/font]
Are the codes available to import to a Harmony 555 learning remote ?
Comfort IR codes are part of the Harmonys library of IR codes for devices which can be downloaded from the Internet
Get the Harmony Application manual for Comfort from here
thnx
