KP06 Firmware 6.003
Implemented LCD display in cases when keypad ID is not polled after 10 seconds - First LCD page shown is \"ID#x Verx.xxx\" and second page is \"Keypad\", \"NOT polled\". When keypad ID is polled by Comfort again, the LCD display will go back to normal automatically.
Changed LCD text when communication failure for 20 seconds. Previously text was “Communication Failure” with own ID. Now, the first LCD page shown is \"ID#x Verx.xxx\" and second page is \"No Bus\", \"Communications\".
Fixed beep handling. Keypad beeps abruptly stopped when speaker off command was received.
Added date display formats in settings menu. Also affects the format in event log with respect to the order of day and month.The possible settings are:-
DD-MM-YY
DD/MM/YY
DD.MM.YY
DD MM YY
MM-DD-YY
MM/DD/YY
MM.DD.YY
MM DD YY
YY-MM-DD
YY/MM/DD
YY.MM.DD
YY MM DD
DD-Mmm-YY
DD/Mmm/YY
DD.Mmm.YY
DD Mmm YY
Added time display format in settings menu.
12 Hour (AM/PM)
24 Hour (HH:MM)
Added combination buttons to work with in some hardware designs, where they do not have volume buttons.
\'3\' & \'#\' is volume up.
\'6\' & \'#\' is volume down.
Added keys \'8\' and \'0\' for changing selections in settings menu, in addition to vol up and down buttons . The \'8\' key is for downward select, similar to volume down key. Note that combination volume up and combination volume down cannot be used in the settings menu.
Cater for new user assignment for Comfort version 6.011 and upwards. Upon boot-up, keypad gets Comfort version to determine which set to display.
Before Comfort v6.011,
  • User 18 is Engineer.
  • User 90 is Keypad.
  • User 91 is Response.
  • User 92 is Phone.
  • User 93 is Pager.
  • User 94 is CMS.
  • User 95 is SMS.
From v6.011 onwards,
  • User 254 is Engineer.
  • User 240 is Keypad.
  • User 241 is Response.
  • User 242 is Phone.
  • User 243 is Pager.
  • User 244 is CMS.
  • User 245 is SMS.
  • User 17 to User 24 for UCM ID1 to 8.
Known Bugs
If a KP06 is installed at ID#1 and a 2nd KP06 is connected with the same ID without switching off the power, the ID of the 2nd KP06 cannot be changed using the * menu. The workaround is to reset Comfort. This applies to previous firmware
The latest KP06 Firmware can be downloaded from
https://www.cytech.biz/kp06_firmware.htm...ory_id=101
