Threads: 50
If on the UCM/Zwave3 I map a device to a counter (e.g Counter 100), would setting Group Address 100 to a specific level (0 - 255) in CBUS translate to the Zwave device being set to the same level by the UCM/Zwave3?
Threads: 476
Cbus address 100 would change the counter 100 value, but it would not affect the Zwave device currently
However it is best to avoid using the same Counters for different purposes, as in future we may allow changing the counter value to also change the Zwave level at the mapped address
Threads: 50
09-28-2012, 02:26 PM
(This post was last modified: 10-01-2012, 03:26 AM by Howser.)
In the example I gave above, Cbus has input (keypad) and Zwave device is a dimmer. I like the idea of Cbus controlling Zwave without using Responses.
