08-25-2012, 04:26 AM
After a long time on other projects, we are finally working on WizComfort again
WizComfort 1.9.3 Beta is now available for download from https://www.cytech.biz/wizcomfort.html?category_id=98
The purpose of the Wizcomfort is
Saved UCM Connection Settings
Bugs Fixed
- As a user interface able to access locally by USB or Ethernet, or remotely by Ethernet In fact USB connection would normally be used only at installation time by the installer, while the user would connect by Ethernet local or remote.
- To allow User-level programming without having to use Comfigurator so they do not change the important engineer settings eg Time program times, record messages
- To assist during Testing and Commissioning of Comfort
- Saved Connection settings from Comfigurator 3.5, ie Local and remote Ethernet IP addresses and USB
- The System Information page should be updated with the correct modules information
- Default should be No, because Ethernet would be the most useful interface. If No, then the features which require Voice should be disabled ie Communications Button.
- This feature ihas been removed
- The button has been removed
- Wizcomfort detects Ethernet connection lost. LU00 also indicates connection lost. Software shows logged out status.
Bugs Fixed
- KP06 in the cclx file caused an Exception
- When the cclx file in which WizComfort was previously set is removed from its original directory AND the Auto-Login setting is set as Yes, then WizComfort had exception.
- \'Read Event Log\' button is pressed in Event Log tab (without first signing-in to the system) l caused a unhandled exception; and if we select Continue then the Read, Save, Open Event Log functions will be disabled
- In Control Menu feedback, the RIO feedback was shown as \'Unknown\'.
- The IR transmission to RIO\'s outputs did not work. The output selections correctly contains the RIO\'s outputs 129 onwards but it is sending to outputs 65 onwards if you see from monitor I/O.
- Input / Output status of SCS / RIO is only updated once after start-up and subsequent status changes will not be updated.
- User 9 had the function to Record User Name; the recorded user name will be used for User 3 instead. Also when sign-in using user 16 code, there will be the function of Recording User Name not under user 16 but under User 10.
- Answering Machine Messages functions i.e. Play New, Play Saved, and Erase are not working even though the commands sent out (KD60, KD61, KD62) comply with the specification. This is a comfort issue, not Wizcomfort. For info only
- In Holidays when a month is selected and then select back to none, the day always comes up with invalid number no matter what day number inserted.
- When sunrise and sunset times are changed from Wizcomfort and then updated to the cclx file, the changes for week 49 - 52 will not get written to the cclx file.
