Threads: 12
In KTouch, with C-bus tab: How to use Key Functions \"Dimmer\" together with \"On-Up\", \"Off-Down\" with which type of C-bus group address and which type of Comfort counter data for dimming purpose? Thanks
Threads: 885
It is important to understand that KTouch is not connected to C-Bus, unless if Comfort is connected to C-Bus through another UCM/Cbus
The KT01 is a Comfort keypad. not a C-Bus device. If you want to control Cbus through the KT01, you use its group addresses to activate counter Responses, and these counter responses to send C-Bus commands.
You can probably program the counters so that it would control the equivalent group address to the same level as what is shown on the KT01, but that may be quite complex
Is that what you are trying to do?
Threads: 12
Yes, that is what I am trying to do for dimming function, because I can use KTouch to switch On-Off groups address nicely. Thanks for quick reply.
