Firmware upgrade by Comfort bus
According http://www.comfortforums.com/forum92/2409.html, I should see a list of all the modules in my system which can be upgraded via the bus... However, when I select Transfer... Firmware Upgrade... For Module connected to Comfort Bus...
I only see the main controller, and not any of my UCM\'s..
I\'m using Comfigurator 3.5.1
My Comfort II Ultra is running latest firmware 6.020
I have 2 UCM/Universal, both running 6.012
I have one UCM/CBUS running 5.234
It\'s the last one I Want to upgrade; the CBUS one... I believe from the aforementioned post, I meet all the minimum requirements...
Any idea why it does not appear on the \"Select Module to Upgrade\" list? - is 5.234 too old to support bus upgrade? but then why don\'t either of my UCM/Universals appear too?
TIA
Paul G.
All modules need to have version 6 firmware in order to upgrade by Comfort bus. It is stated on the post mentioned
If the module is version 5 you need to use the UCM programming cable method
The UCM/Universal should be seen in the list
Can you scan for modules and see if they are detected with the corrrect type and firmware?
Also what is your UCM firmware?
