Threads: 1
Hi I have a Comfort II Ultra unit with C-Bus and Ether-02 UCM\'s After I had an alarm recently i went to the history to get the event log and found it to be full of events Time/Date Change 18.
The firware is
ULT 6.011
Cbus 6.010
Eth02 6.012
I attached the log file as an example.
While i am asking the question. Two more in realtion to the log file.
Can the Log File be made to read most recent items first?
Is their a Responce action that can be used to clear the Log?
Threads: 1
06-24-2012, 08:02 AM
(This post was last modified: 06-24-2012, 08:03 AM by colin.)
Ok trying to add the attachment of my log file but it wont submit ??
Here is a small copy as an example
06/15 11:11 Date/Time Change 18
06/15 11:12 Date/Time Change 18
06/15 11:13 Date/Time Change 18
06/15 11:14 Date/Time Change 18
06/15 11:15 Date/Time Change 18
06/15 11:16 Date/Time Change 18
06/15 11:46 Date/Time Change 18
06/15 11:47 Date/Time Change 18
06/15 11:48 Date/Time Change 18
06/15 11:49 Date/Time Change 18
06/15 11:50 Date/Time Change 18
06/15 11:51 Date/Time Change 18
06/15 11:52 Date/Time Change 18
06/15 11:53 Date/Time Change 18
06/15 11:54 Date/Time Change 18
06/15 11:55 Date/Time Change 18
06/15 11:56 Date/Time Change 18
06/15 11:57 Date/Time Change 18
06/15 11:58 Date/Time Change 18
06/15 11:59 Date/Time Change 18
06/15 12:29 Date/Time Change 18
06/15 12:30 Date/Time Change 18
06/15 12:31 Date/Time Change 18
06/15 12:32 Date/Time Change 18
06/15 12:33 Date/Time Change 18
06/15 12:34 Date/Time Change 18
06/15 13:04 Date/Time Change 18
06/15 13:05 Date/Time Change 18
06/15 13:06 Date/Time Change 18
06/15 13:07 Date/Time Change 18
06/15 13:08 Date/Time Change 18
06/15 13:09 Date/Time Change 18
06/15 13:10 Date/Time Change 18
06/15 13:40 Date/Time Change 18
06/15 13:41 Date/Time Change 18
Threads: 62
06-24-2012, 08:34 AM
(This post was last modified: 06-24-2012, 08:36 AM by Ingo.)
18 is probably your UCM/Cbus. Check the Cbus side for anything strange - try using the Cbus Diagnostic Utility.
Ingo
Threads: 1
06-24-2012, 08:43 AM
(This post was last modified: 06-24-2012, 08:44 AM by colin.)
Thaks, Due to Trouble with my Post i lost part of what i wanted to post
I am Currently Monitoring C-Bus but am not seeing a corelation between the two. The whole log has events where their are a burst of time/change events loged over a period of less than a minute and then the event may show up on another day where they are a few minutes part, and again where thet are 15 or 30 minute apart.
and then not at all.
I am in the process of logging everything, in order to try and make some sence of what is going on.
Threads: 476
18 is the address of UCM ID 2 which presumably is the Cbus UCM so it indicates that Cbus is sending a date/time update to Comfort
Threads: 2
I am having the same problem, the event log keep on saying time change. what could be the problem
Threads: 476
Time Change 18 means the UCM at ID#2 is sending a time change to Comfort
If you have a Cbus network connected to the UCM, this may be a known problem with Cbus date and time
Upgrade your UCM/Cbus to the latest firmware version. You will have to talk to your installer
