03-31-2012, 10:24 AM
Quickie,
The TP command; what is the purpose/usage of the \"FF - Ignore Enable\" setting?
TP - Time Program (UCM 5.65, O4.209)
PC: TPttee[DD] [HH][MM] [RRRR]
UCM: OK
Sets the Time Program parameters
tt is the TimeProgram Number
ee=0 for on/off value, 0 = off, 1 = on, FF for ignore enable setting
DD for Day of week combination Bit 0 = Monday, Bit 1 = Tuesday,... Bit 6 = Sunday, Bit 7 = Holiday
HH for Hours in BCD notation 00 to 59 e.g. 22 is 10 PM
MM for Minutes in BCD notation 00 to 59 e.g. 45 is 45 minutes
RR for Response number - can be 1 byte or 2 byte response. If 2 byte responses, least significant
byte followed by most significant byte. If response < 256, the most significant byte (0) can be omitted.
Ultra version 4.216 will accept TP with 2 byte responses
Each TP message can set one or more parameters of the Time Program
UCM: OK
