Cytech Logic Engine
Cytech\'s new Logic Engine is a Programmable Controller for Automation Applications which can replace PLCs and with the ability to interface to most  Home automation Systems.
Features
  • 8 inputs, 8 open-collector outputs, expandable to 216 Inputs and 216 outputs
  • 12V - 1Amp wall mount adaptor
  • EN01 enclosure 310 x 350 x 95 mm. CM9000-LOG is without EN01
  • 32 Time Programs
  • 1024 Responses
  • Sunrise/Sunset Times with automatic daylight saving time changes
  • able to send 250 IR Codes to AV and airconditioners
Applications
  • Central Controller for AV, Lighting, Blinds, Heating, Airconditioning, Irrigation etc with Scheduling and logic condtitions (If/Then/Else)
  • Interface to RS232, RS485, Ethernet, C-Bus, KNX, Z-Wave, Velbus,
  • Interface between 2 systems eg Zwave to KNX etc
  • Hotel Room Bedside Panels using SCS switches
  • iPhone app to control and monitor system
  • Touchscreen control using KT03 monochrome touchscreen
  • Control on/off lighting via two way switches with TWS ( with relay and current sensor)
  • Control airconditioning  and AV equipment via IR signals (250 codes)
Options/Expansions
  • Up to 8  UCMs (RS232, USB, Ethernet, Cbus, KNX, Zwave, Velbus, Universal)
  • Up to 15 SCS or RIO
  • Expandable to 64 Inputs/outputs using LEM and SEM, and 120 I/O using RIO
  • KT03 Monochrome Touchscreen Keypad
This is essentially a Comfort PCB without the alarm, dialer, voice, recording, intercom functions.
Logic Engine Differences with Comfort
  1. It  is NOT an alarm system. Inputs trigger Responses, do not activate alarms.
  2. It is not connected to the phone line and does not auto-answer calls or dial to phones
  3. Does not have  a voice menu or  make announcements
  4. No  Message recording and Playback
  5. No Intercom Functions
  6. No battery charger
Part Numbers
  1. CP9000-LOG Logic Engine with EN01 Enclosure 310 x 350 x 95 mm with12V 1 A.
  2. CM9000-LOG Logic Engine PCB only with power supply 12V 1A
Link to Logic Engine on Cytech Website https://www.cytech.biz/cytech_logic_engine.html
Download the brochure from https://www.cytech.biz/logic_engine_brochure.html
There is a forum for Logic Engine at  http://www.comfortforums.com/view_topic.php?id=3336&forum_id=117
This programming with configurator , or new program ?
Programming is with Comfigurator 3.4.3 and above. For File > New select Logic Engine
Very very interesting, but why not to put it in a DIN-RAIL mount?
Very good idea, any indication of price btw ?
We do not have DIN rail
I would imagine the din rail solution would be very awkward to expand and wire to etc also.
Any indication of price indent ? And when is this available ?
Regards,
Eamon
What about and even more scaled down version that uses the existing Comfort IO\'s and cannot expand beyond that? All that you then need is a KA/KB and 12V connections and if that fits inside a DIN rail mount it would be awesome. See Clipsal\'s PAC module as a reference for size.
Ingo
No select -Logicengine in my configurator . My version is 3.4.4
selevt Comfort II Logic not Logic engine
Prices wil be avaialble soon
