02-19-2012, 09:19 PM
Hello,
Using Comfort Opt with an UCM/KNX, I\'ve mapped a virtual port to a KNX sensor. So, when the sensor detects a failure it returns a message to the defined group and Comfort intercepts this message. Then, Comfort activated the corresponding zone alarm if activated. So, everithing works very well.
Unfortunatelly, when I disarm the Comfort it\'s not possible to arm it afterwards. This is because the KNX value is still mapped into Comfort table. But there\'s no Counter or Sensor registers available that I can decrement to reset the virtual zone input. If I try to arm Confort, it returns me an Arm Failure State corresponding to this Virtual Zone Input.
The only way to solve that is to write a complex script with the requested actions but I would prefer to simply be able to reset the Virtual Zone Input.
NB. In my case it\'s not an option to ask KNX sensor to send a Zero state after a given time.
Do you have some other way to solve my issue ?
Thanks.
auredor
Thanks.
auredor
