12-10-2011, 08:47 PM
Does Comfort II still need a Time Program/Response for DST adjustment?
I\'m porting my config from Comport I.
Thanks,
Thanks,
DST Adjust needed for Comfort II
I\'m porting my config from Comport I. Thanks,
12-11-2011, 02:15 AM
Comfort 2 time is more accurate.
You should not need the same amount of time adjustment if any
12-11-2011, 10:36 PM
But do I need a response to adjust the time for Day Light Saving? Or is this automatic in Comfort II?
thanks
12-12-2011, 04:53 AM
Comfort 2 will automatically change the time on the correct day at the start and end of Daylight Saving Time. You need to select your correct location in Schedule > Sunrise/Sunset. See the forum topic here http://www.comfortforums.com/forum92/1004.html
| 2 Guest(s) |
