Threads: 55
Map 1 bit Arm to Away to a group address seems not working.
Sending \"1\" from KNX bus to this group, does nothing in Comfort.
Can you check please?
Thanks.
Threads: 885
This is the most commonly used function for KNX which should definately work
Can you send your cclx file to support@cytech.biz
Threads: 55
No, thanks, i will investigate more.
Shure is my mistake.
Thank you.
Threads: 7
Try updating the firmeware...it worked for me..
Threads: 5
I seem to have the same problem after updating the firmware. Before it worked fine. Now I have all the modules last firmware and Comfort is sending time to KNX but Night Arming from KNX does not work.
Threads: 476
Did you WRITE to EEPROM for the UCM/KNX?
