Whats New in Comfort App v 1.45
The new version 1.45 of the Comfort iPhone app fixes a problem with the initial connection to Comfort due to iOS5 reported in http://www.comfortforums.com/forum96/2520.html
This new version 1.4.5 requires iOS5. iPhones and iPads with  iOS4 will not be able to upgrade or install due to a bug
Those with 1.4.4 do no need to upgrade because 1.4.5  only fixes a bug for connection using iOS5. The next version will fix that and allow iOS4 to install
what\'s if i want to install version V1.44, where can i get the .ipa file since we\'re still using iOS V4.3.1?
Cant you just upgrade the app in the normal way? Why do you need an ipa file?
[user=86]ident[/user] wrote:
Quote:Cant you just upgrade the app in the normal way? Why do you need an ipa file?
This latest version of the app 1.45 requires a minimum of IOS 5 which will not install on older IOS devices.
There are still a lot of devices out there that can not install IOS 5 so can not use this app.
I see
We will be coming out with a new version which is compatible with older iOS
However the app version 1.45 just fixes a problem with iOS5 so there is nothing lost by not upgrading to 1.45
