Upgrading UCM Firmware
I have comfort firmware 5.211 and UCM/Ethernet 5.212 and UCM/CBUS 5.208.
I was waiting for the latest version of Comfort firmware which allows UCM or Comfort firmware updates direct from Comfigurator.  I was hoping therefore not to need to have to get hold of another UCM, however it seems I will still need one to do the initial upgrade to get the UCM to version 6.008.
Are the following steps correct-
1. Upgrade Comfort firmware to 6.005 using the programming cable from the existing UCM Ethernet 5.212.
2. Obtain a 2nd UCM to update the firmware of UCM Ethernet from 5.212 to 6.008
3. Future firmware upgrades can then be done direct from Comfigurator to either Comfort or UCM with no cable or 2nd UCM required.
Questions
1. Is above correct, or is there another way without needing a 2nd UCM?
2. Once the updates are done, can you therefore in future update the Comfort and/or UCM firmware remotely from an internet connection, without having to open the comfort system?
Yes you will still need to upgrade your Comfort and UCM firmware 1 last time using the programming cable
Once the firmware is 6.xxx, you can upgrade the UCM/Ethernet by direct connect, and the UCM/CBus and Comfort via the Coomfort Bus, using Comfigurator 3.3.1 or above
The procedures are at http://www.comfortforums.com/forum92/2409.html
With a UCM/Ethernet and a port forwarding router configuration you will be able to upgrade the firmware from the Internet. However as protection you will have to press F0 on the keypad to allow firmare upgrade
I am sure someone will be able to help you upgrade your  UCM
OK, thanks.
Anyone out there have a UCM they don\'t mind lending me a for a day?
Add your location to your profile?  (e.g. Town/County/Country)
Kingston, Surrey. Thanks
If you have not had an offer yet send me personal message. My son works in Surbiton on Saturdays ...
Nigel
Our you could send it over to us and we will update it for you!
Thanks for the offer Nigel.  All sorted now, I sent it off to Andy who did the update for me. - Thanks again Andy Wink
I have a similar problem, but do not have a UCM upgrade cable.
Where can one order such a cable from?
Thank you
Send me you address and i will send one i the post FOC
6 Guest(s)
