09-08-2011, 07:21 PM
When you do a read from Comfort it only reads the items under the comfort tab. How do you get the info from the modules tab. I am using ver 3.1.1.0 of the software.
Scanning for Modules Does Not Work
09-09-2011, 02:12 AM
Reading from Comfort should also populate the Modules Tab
However there is a minimum version of firmware that suppports detection of modules in the Modules Tab. These are listed at http://www.comfortforums.com/forum92/2103.html
09-10-2011, 02:35 AM
From raygregg114
Quote:can\'t scan as comfort or ucm does not allow. Comfort ver 5.164 and UCM ver 5.092. Do these need updated, if so is there instructions and downloads available. Thanks for your help so far.UCM 5.092 is the old UCM01 hardware which cannot perform the upgrade on Comfort and other modules, nor can its own firmware be upgraded. This was phased out and replaced by the newre flash based UCMs about 7 years ago See the pictures of the newer UCMs and the old UCM01 at http://www.comfortforums.com/view_topic.php?id=46&forum_id=4 You will need to buy a new UCM/232, /ETherenet or /USB in order to scan and to be able to upgrade its own firmware or other comfort firmware bia the Comfort Bus. The UCM/Ethernet also supports the free Comfort iPhone app, see http://www.comfortforums.com/forum96/2372.html Did you buy the Comfort and UCM at the same time? I see you have a new Comfort II but an old UCM
09-11-2011, 11:24 AM
both where bought just over a year ago. Why would someone still be selling something that is out of date.
09-11-2011, 11:35 AM
Did you buy second-hand then?
Maybe it\'s worth you posting a picture of your card. I purchased a UCM/Eth card a few years back which was sold as a UCM01 but was actually an early generation UCM05 with flash firmware which I\'ve been upgrading since. Not saying that\'s what you\'ve got but happened for me! Has it got the big chip on it in recessed socket or the smaller low profile chip soldered directly on the board? Julian
09-12-2011, 01:44 AM
UCM 5.092 is definately a UCM01. The new UCMs with flash start from 5.100. You should not have been sold an old product. Where did you buy it from?
09-12-2011, 08:12 AM
This was purchased from Comfort Home Controls website - http://www.home-control.co.uk/index_products.html.
09-12-2011, 08:16 AM
Check out this page
http://www.comfortforums.com/forum56/1082.html
09-12-2011, 09:05 AM
I purchased my total system from these people. Is the anything I can do or do I now have to go again and purchase more parts.
| 2 Guest(s) |
