07-26-2010, 11:59 AM
Has anyone any experience of using the Comfort Door Station Interface DM02 with Panasonic PBX Door Phones (e.g. KX-TES824 / KX TA824)?
If so, the DM02 manual cautions that \"Some third party intercoms will not turn on their audio path until their in-house handset is off hook. If DM02 is used with this type of intercom, a means to simulate the handset going off hook and on hook is needed so as to allow the mic and speaker on the intercom to be activated.\" It outlines how to do that.
At a guess this might be the case in PBX situations.
Can you advise whether the Panasonic system does or does not turn on the audio path as mentioned in the manual, and if so how you handled the work around?
Thanks in advance.
Thanks in advance.
