The button Reset (Reset to Factory Default) in the Zwave Configurator resets the UCM/ZWAVE to Factory Default including the Z-wave properties and Counter assignments.
This does not remove the UCM/ZWAVE from the Z-wave network - that can only be done by the Primary controller.
AVOID THIS UNLESS THE UCM/ZWAVE IS NOT TO BE USED FOR THE CURRENT Z-WAVE NETWORK, OTHERWISE A NEW LEARN OPERATION WILL ADD A DUPLICATE NODE FOR THE UCM/ZWAVE NETWORK
Refer to the UCM/Zwave manual at https://www.cytech.biz/ucmzwave_manual.html
