Pronto, Comfort 1 and Ethernet UCM
Hi Guys,
Am i correct in assuming that this will ONLY work with the ethernet UCM, and not with the serial UCM and the philips pronto RFX9600 extender?
Also i was told i can use the ethernet UCM with my version of comfort 1, but not able to use it for control with the ipod, would this also be the case with the Pronto 9600?
\"Correct, you have Comfort I Ultra 4.156
You should be able to use a UCM/Ethernet with this system
But not if you are planning to use the Comfort iPhone app as you need Comfort II for that\" - Cytech admin
Kevin
Comfort I should work with UCM/Ethrnet
However I am not sure if Pronto module will work fully with Comfort I as it was developed with Comfort II. Some of the commands may depend on Comfort 2
We have not tested the RFX9600 extender. If it has the same commands then it may be able to work with UCM/232
Thanks, i shall have a play with the ucm232 see if i can work the protocols first.
Hi does anyone had the RS232 protocals availible for the comfort system so i can try and work a RFX9600 - UCM/232 for my comfort?
Kev.
Send an email to support@cytech.biz. We will send the protocol in return
By the way our new Universal UCM supports RFXCom already but that needs Comfort 2
