08-13-2011, 09:37 AM
The new 6.xxx series module firmwares are absolutely brilliant. Many thanks for bring this feature to us...happy days!
Having seen ULT and UCM/GSM v6.xxx\'s this weekend (both of which I\'ve sucessfully applied) I\'d like to understand the dev schedule/order for the remainder.
Would it be possible for you to list out the UCM\'s in the order you are proposing to release including of course any already done? Dates if you can but we won\'t hold you to these of course, its just to give us a rough idea of your timescale thinking!
I\'m also hoping you will release v6.xxx versions of firmware even if the only need for that release is to add the upgrade logic. Why? Because then we know we can remove the cover from the panel for the last time, upgrade all modules via the programming cable to v6.xxx and then that\'s the last time we need to do an upgrade via cover off.
Hope that makes sense and look forward to seeing a tentative schedule.
