Issues since CBUS UCM upgrade
I\'ve got a strange issue where Comfort and CBUS occaisionally aren\'t talking - I have various CBUS buttons to kick off Comfort responses for critical items, and have been doing so for around 5 years with no issues.
I\'ve recently upgraded the CBUS UCM to 5.235 (the latest) - co-incidence ?
I can see in the CBUS monitor the button is pressed, but Comfort I/O monitor shows no signs of activity. The HomeSeer log shows no real activity, so it cannot be bus traffic overload (that is being reported)
Previously, I have been pressing the \"reset\" button on the CBUS UCM to kick things back into life, but tonight, I kept trying the same CBUS button until eventually it started working again. The same code on this particular button has not changed in 4 years.
How can we debug this ?
Can I downgrade to the previous version which had no issues ?
Yes you can change the firmware back to the previous version
CBus 5.216 can be downloaded from this post http://www.comfortforums.com/forum85/1965.html
Let us know if you encounter the same problem
I have similar issues.
Ingo
HI
I was on that firmware before, and I didn\'t have that problem.
Before I go through the pain of a downgrade, would Cytech like to debug the issue with me and produce a fix ? I would suggest removing the current firmware from download until such time as a resolution can be found.
We have not managed to duplicate that problem yet
we have been trying to debug it with Ingo
There may be an issue with the use of the Cbus Toolkit which may be causing  this problem
I don\'t run toolkit except when re-configuring the system, or when looking at the log after this Comfort problem appears.
The fact the previous firmware worked, and this latest firmware has problems, puts the problem firmly in the CBUS UCM arena.
Yes we will try to find what was the problem and get a fix
What can we do to help get this resolved quickly ?
We will work with you offline thanks
