UCM 6.002
The latest UCM Firmware can be downloaded from https://www.cytech.biz/ucm_firmware.html...ory_id=101
Instructions for upgrading the UCM firmware can be found on http://www.comfortforums.com/forum4/1782.html
This UCM firmware applies to UCM/USB, UCM/Ethernet and UCM/232
[size=\"3\"]Version 6.002 (6 June 2011)[/size]
Bug Fixes
  1. Fixed BUG from UCM 5.203  Comfort bypass zone does not get reported correctly to UCM
  2. Fixed BUG overflow of rs485 transmit buffer caused endless loop leading to watchdog reset. This does not occur in mormal; circumstances
Improvements and New Features
  1. Implemented CM command for UCM for Control Menu Commands for iPhone app.
  2. Implemented UB05 firmware Upgrade for UCM directly connected to PC. Instructions on how to upgrade the UCMs own firmware can be found in the forum http://www.comfortforums.com/forum4/2283.html
  3. DT will not be reported when seconds change only is reported from the PC
  4. Size of data in Comfort Rs485 bus message increased from 64 to 69
Please note that new systems may not come with the latest firmware due to existing sticks in the supply chain. Installers should upgrade to the latest firmware before installation. Existing installed systems do not need the upgraded firmware unless the functionality is to be updated or there are bugs to be fixed which affect the installation.
I have a UCM/Ethernet that could do with the update.
Anyone in the UK want to arrange a firmware upgrade?
Great.  I see you\'ve implemented my request for commands for the control menu.  Where can I get the protocol?
Thanks,
Clinton.
I see the rs232 document has been updated with the CM command.  Thanks.
Is there anyway I can get the menu item text through the protocol?
Cheers,
Clinton.
The menu text cannot be obtained from Comfort as they are not stored in Comfort, only in Comfigurator
UCM 6.002 can be used to upgrade its own firmware so that you do not need another UCM with a programming cable in future
See instructions at http://www.comfortforums.com/forum4/2283.html
Just something I found with the new firmware, the DT command doesn\'t return the current Date & Time as stated by the Serial protocol documentation.
[size=2]
Quote:DT without any parameters will cause the UCM to send the current date and time in a DT report
Ingo
[/size]
You are right, that seems to be a bug that crept in due to the changes in handling date and time recently. The engineers will look at it in the backroom
[user=3375]bs85[/user] wrote:
I wouldnt mind I am near Windsor - where abouts are you?
Stuart
Stuart[/quote]
Stuart I have sent you a PM
