Threads: 219
UCM firmware 5.228 is posted I see in the main Cytech firmware download area.
Can you share with us what is fixed between this version and the previous 5.212 version?
Threads: 219
05-02-2011, 06:59 AM
(This post was last modified: 09-17-2011, 10:22 AM by ident.)
Nice, thanks.
What can you tell us about the new ETH daughterboard?
It is 100Mb/s?
Does it support multiple connections?
Can we upgrade our existing UCM/Eth01 (UCM05 based) to it?
When will it be available?
etc etc
J
Threads: 888
The UCM 5.228 firmware will support the ETH02 when it is released. More details will be provided once the product is ready to be announced. EM500 will replace the EM100 which may be phased out by the manufacturer in the future
Note that Comfigurator 3.2.8 will allow UCM/Ethernet firmware 5.228 with EM100 to use the Bus Monitor whereas previously Bus Monitor was disabled when using ther Ethernet to connect
Threads: 476
At the time the ETH02 was produced the GA1000 was not ready yet, so the connections are not guaranteed to work. The GA1000 support was just announcced so we are studying
Threads: 206
Can you keep us posted in this - would it have a remote antene or are you gioing to supply a plastic enclosure?
