04-24-2011, 10:42 AM
Hello!
I use Comfort as an alarm panel for intrusion, fire and flood detection in a KNX automated house. We have one flood detector in a swimming pool engine room which is separate from the house and we have no more means of additional cabling. However, we have a KNX bus there and we can connect the flood detector to a KNX binary input. I.e. we can have this signal as a 1-bit switch with an arbitrary group address.
I see that in Comfigurator I can define some unused zones as virtual input. In my case, they would be zones 9-16 (LEM on the main panel which is not installed) or any other between 33 and 64.
However, when I try to define any zone as virtual, this particular setting is disabled (the letters are of faint blueish color and the option can\'t be checked) - see attached screenshot.
Am I doing something wrong?
Comfigurator 3.2.8.0
Comfort II Ultra
Filesystem 34
Firmware 254
Comfort version & revision 5.206
UCM/KNX 5.213, ID=2
UCM/Ethernet 5.212, ID=1
SEM 5.175 with LEM, ID=1
Windows XP Proffessional SP3
Comfort II Ultra
Filesystem 34
Firmware 254
UCM/KNX 5.213, ID=2
