Threads: 30
04-14-2011, 10:19 PM
(This post was last modified: 07-01-2013, 01:27 PM by ident.)
I have only UCM CBUS and UCM/Ethernet in my system (firmware verion 5). How do I go about upgrading the firmware of the UCM/Ethernet?
Threads: 476
You will need another UCM to upgrade a UCM firmware. A UCM cannot upgrade its own firmware. Perhaps you know someone who has a UCM so you can upgrade each others UCM firmware
Threads: 9
I have a UCM/Ethernet that could do with an update.
rodime maybe one of us could mail there UCM so that both could be upgraded?
Threads: 30
Sure. Send me an email with your address.
Not really an ideal solution though, the way I see it you are unlikely to have two such UCMs in an install. Makes remote update impossible also.
Is anyone working on a way that you can simply flash directly to the UCM, much the same way as you can for a PC Bios?
Threads: 476
In fact we are working on a new UCM firmware which will allow a UCM to be directly upgraded. If the upgrade is not urgent I suggest to wait for the new firmware for a few months
Threads: 219
Thanks that\'s great news and will make like easier for us all.
Threads: 219
This new self upgrading UCM; how\'s it coming along?
Will the UCM have to be already flashed to a certain revision (using another UCM) before the UCM will then be able to onwardly self-flash?
If so I hope you\'ll be able to publish a \"Placebo firmware\" at the same time so that we can test it post initial (old method) upgrade.
Threads: 885
It is still in progress. It will need a new version of Comfigurator to support it.
Yes, you will have to upgrade the UCM to the new firmware using another UCM before it can become self-upgrading. The upgraded UCM will still be able to use the \"old\" method of using the programming cable to upgrade other UCMs and modules
I dont know what you mean by the \"placebo\" firmware and why you would need that
