This is a new beta version which willl eventually replace Comfigurator 3.2.5, see http://www.comfortforums.com/forum20/2111.html
New Features
New Features
- Scenarios Import and Export. A Scenario is a collection of Events and Responses which implement a function in Comfort. For example, Intruder Alarm Type causes the lights in the house to flash until the system is disarmed. This can be programmed in Comfigurator and exported as a Scenario file with extension .crsx. The Scenario can be imported into another file so that the same functionality can be implemented. This replaces the previous Responses Import and Export feature which was limited to Responses, and did not include the Events which trigger the Responses. This will be a very useful and important feature. See http://www.comfortforums.com/forum92/2185.html for a tutorial on how to use Scenarios
- Improvements and more complete support for Universal UCM
- Play Reminder Action - added Play Reminder for All Keypads, and All UCMs
- When the number of Modules in Modules and Settings does not match that in the Modules Tab, a warning message is shown \"[color=\"#ff5500\"][color=\"#ff0000\"]Please do a Scan for Modules to determine the numbers of each module connected to Comfort[/color] [/color]\" The discrepancy could be because of conversion from Comfigurator 2 ccl files or because the configuration was created in an older version of Comfigurator 3 where the Scan Modules function was not available
- In Options > Settings > UCM Connection for USB Interface, a button \"Scan for USB Devices\" is added. Previously when a UCM/USB is connected to the USB port of the computer, yoiu had to exit from the Options > Settings page in order to detect the USB. The new button allows the USB to be detected while on the page.
- When connecting to KT03 via USB in the KT03 Configuration screen, if Comfigurator fails to connect, a message \"[color=\"#ff0000\"]Failed to connect to KT03. Connect the PC directly to the USB Port of the KT03. If there is another UCM/USB, select the serial number for the KT03 USB[/color]\" Initial problems encounteredc by users is that they did not realise that the computer has to be connected to KT03 directly, and that the USB serial number for KT03 has to be selected if there is a UCM/USB which also has a USB serial number. Selecting the UCM/USB serial number would cause Comfigurator to try to write the KT03 configurationto the UCM/USB which would not work.
- Exception occured when editing KT03 Configuration using Windows 7 Professional (Other Win7 versions may be affected as well). Clicking on the Pages Tab caused unhandled Exception. Clicking OK caused another exception.
- When a page in KT03 is renamed, the name is not reflected in other items which reference the changed page
- Reading from a Comfort programmed with older Comfigurator versions sometimes caused an exception after the Read is complete.
- When the name of an Alarm Type is changed, the Zone Types which trigger that alarm type still showed the old name until the Alarm Type for that Zone type is selected again.
- IR Transmit codes which had codes numbered near the end of the table ie 250 but which have gaps in the IR numbers may overflow into the Alarm Types Table without warning causing the Alarm Types to have the wrong information. It is still recommended that there should be no gaps in the IR codes as this takes up extra space in memory.
- Selective Write causes incomplete data to be written due to Comfigurator resetting Comfort before the write is complete. Please use Full Write instead of Selective Write. This is not a new issue, and affects previous versions of Comfigurator. See http://www.comfortforums.com/view_topic.php?id=2197&forum_id=20 for full details.
- For Universal UCM, when a referenced Response number changes due to manipulation of other Response numbers, the change is not reflected in the Universal UCM response.
- The Alphanumeric Text ID feature for UCM/GSM does not work on Comfort Optimum because of an error in the IOMAP.CYM file. Contact Cytech for the correct file
