Threads: 206
What more needs to be said...
A majority of Comfort installs that I have experience of are not connected to Ethernet cabling and to do so is not an easy task.
A UCM with wireless n capability that wil connect to the Ethernet woud be a major break through and allow the iPhone upgrade that is so desperately needed a way forward.
Threads: 0
02-10-2014, 01:42 AM
(This post was last modified: 02-10-2014, 01:42 AM by ukhauk.)
The TP-Link TP-WR702N are fantastic little devices essential for commissioning on site
Threads: 885
The X10 interface required a XM10E or similar X10 transceiver with mains plug
These Homeplug wallmount adaptors are already available and it would not make sense to manufacture one of those as these are consumer products already produced at very low cost. It would be cheaper to buy one of those at retail shops.
Do you mean then to have the ethernet connection on Comfort itself to replace the X10?
Threads: 219
Chiu
In part yes put Ethernet on the main PCB.
Was also thinking as homeplug was a standard and though in a plug sized device (for connection and maybe heat dissipation) the actually comms components inside it would probably be pretty small footprint and also fit on the PCB (single chip?). That said I\'ve never taken one apart. I see what you mean though about you would be more expensive to manufacture.
Jules
