02-02-2011, 02:11 PM
I have a home automation system that will close the blinds on sun down. This can occur when the house is unoccupied. I want to avoid false triggering. What would be the easiest method of disabling the PIR detectors while the blinds close then reseting them once the operation is finished? The automation system is X-10 so it could be used through the relay module or is it possible for comfort to monitor the state of an x-10 unit
Lenny
Lenny
