The new release of KT03 firmware can be downloaded from https://www.cytech.biz/kt03_firmware.html
The new firmware KT03 1.007 has been released. The changes are
Bug Fixes
Bug Fixes
- [color=\"#ff0000\"]Screen may go blank and seem to hang. This may happen when the LCD has timed out and an alarm occurs. Need to reset KT03
[/color] - IR Remote enable function was reversed in Setup > System page
- Time-out settings for screen off was not correct, and was not saved in memory after reset
- Volume setting after reset was not correct
- When a button is configured to jump to another page and do another action, sometimes the jump will happen but the action is not done
- Read and Write EEPROM for external UCMs, eg KNX, Velbus, Universal, Zwave do not work when using KT03 USB connection as a UCM
