Threads: 888
Do you have a 12V 7 AH standby battery connected to Comfort? I suspect that during an alarm, the siren may be taking too much current and you may have no battery or a weak battery which is unable to supply enough current for normmal operation of the DTMF detection.
Also is yours a Comfort I or II and what is the firmware version?
Threads: 3
Hi, Slychiu, thanks for your reply.
Yes, I do have a 12V 7AH battery connected to Comfort II, with PCB PC01-050B and firmware ULT 5.164.
I thought that the problem could be with the siren too, although when Comfort calls me to announce an intruder alarm, I can still press 1 to repeat the message, but cannot log in using *code#
Threads: 3
Ok, downloaded & installed the latest Comfigurator version, saved my old .ccl file as a .cclx file, updated the tuning parameters (I checked and the parameters did change) and downloaded into Comfort. But the problem is still there: cannot login when Comfort has an intruder alarm triggered, only when security is off. I\'ve disconnected the siren and managed to login while in an alarm state, so the problem is definitely when the siren is active. How can I check if my battery is too weak? Comfort doesn\'t seem to be charging it (no charging lights on in the PCB) so I guess it should be fully charged?!
Threads: 888
This may be due to a marginal DTMF sensitivity issue which manifests when the siren is sounding
Go to Configuration > Tuning Parameters. Look for index 45 (DTMF Sensitivity) default value is 18. This number is the sensitivity of DTMF detection and lower numbers are more senstive
Try changing the number lower say by 2 steps write selective to Comfort and try again
Telephone lines have different attenuation for DTMF signals so this adjustment sometimes is necessary
Threads: 888
When the alarm goes off and the system is dialing to your mobile phone, are you also in the house? The siren sounds if too loud may be affecting the DTMF tones as DTMF is also a sound
