12-22-2010, 01:06 PM
The KT03 LCD appears sharper ie better contrast when configured as Landscape Inverted instead of Landscape. This means the KT03 can be mounted at 180 degrees with the speaker grille on the left. The only problem is the LED icons are upside down. We will be supplying a reversed cutsheet strip free of charge for those who require this option
Note that the Wallbox must be mounted into the wall also at 180 degrees as the KT03 can fit inside only one way
