GSM UCM Version
When I send a u? to my GSM UCM that I purchased recently it always returns 130D0000
So the 13 is correct as this is UCM no 3 in my setup and 0D(13) is correct for a GSM but then version and revision numbers are zero.
Is this a know issue with the GSM UCM\'s?
My Ethernet and CBUS UCM both report correctly to the u?
My Comfort Firmware is 5.204
Thanks  Phil
 That is because the UCM/GSM firmware needs to be a minimium version in order to respond to the u? query and not all UCM types supported this feature yet
We have recently released a new UCM/GSM firmware GSM5.201 which you can download from our website at https://www.cytech.biz/ucmgsm_firmware.h...ory_id=101
Follow the instructions on the forum topic http://www.comfortforums.com/forum4/1782.html to upgrade the UCM/GSM firmware. Note that your UCM/USB, /232 or Ethernet firmware must be 5.178 in order to use for upgrading
