Lost single button arming
Hi, I recently rebuilt the PC I use to manage my comfort system ( Comfort 1 Ultra). I installed the new version of comfigurator (3.2.4.0) and opened my old config file. I made just once change to a response and downloaded all of the settings.
I can\'t now set the alarm to away mode with the single button that I used previously I have to type in my user code and press 1 to arm. I can\'t seem to find a setting to correct this but assume there is just a tick box in comfigurator. Where is it?
Many Thanks
In Control > Keypad Look for the Away Key, assign the Response \"KeyArmAwayFrom SecurityOff\" and uncheck the Need Code Box as shown in the screenshot
This programs the AWAY key to arm to Away mode and not require a code
Your old file (presumably in Comfigurator 2) should have been converted to cclx for Comfigurator 3. If the file conversion was not correct somehow, please send your old file to support@cytech.biz so we can examine
We have seen your config file, thanks
The Key Arm Responses in the file are wrong
eg in your file
KeyArmAwayFromSecurityOff
GetParameterValue SecurityMode
If SecurityMode = SecurityOff Then
    Exit Response
End If
KeyswitchArm AwayMode
End
The correct Response which can be examined in a default template should be
End If
End
You can see the difference in logic between the two and why the first one would not work
This problem may have been caused by conversion to an earlier version of Comfigurator 3 which has been fixed
Using Comfigurator V3.3.3.0, I created a new project and did a transfer Read (Comfort -> PC) from Comfort I Ultra. The project had the same Response logic issues as above for the Away and Night mode.
If you do a Read from Comfort you will overwrite the file you have on Comfigurator so it does not matter what project you have created
The config in Comfort may have been created using a very old version of Comfigurator which may have been corrupted Once you fix the  Response and write back to Comfort that should fix it
Yes, I used an empty project to import the Comfort project into. Got an error prompt \"Communication Error or Comfort or UCM firmware does not support scan\" (attached) about 4 times in the process, but Comfigurator reported that the project was imported. I am using UCM/USM Version 6.008.
You may get this message if some of the modules firmware are too old (ie before (5.178) and do not suppprt the scan function
Check the Modules Tab after scanning.
Many of the modules firmware can be upgraded using the UCM programming cable
